"unresponsive SCRIPT message" - Kawasaki Versys Forum
Verticalscope Forum Support / Help (Kawasakiversys.com) Questions about forum functionality or suggestions for improvement. Need help finding what you're looking for? Let us know here!
 2Likes
  • 1 Post By Fly-Sig
  • 1 Post By fasteddiecopeman
post #1 of 14 (permalink) Old 08-07-2016, 05:51 PM Thread Starter
Lately (last few weeks) I keep getting this message after I post something
and it's a REAL PITA, as it comes back several times before I can 'move on', and probably TRIPLES my time on the Forum.
Any thoughts or solutions...?
post #2 of 14 (permalink) Old 08-07-2016, 06:18 PM
Unresponsive Script Wait / KILL ?????
Ever since the password change it takes two to 3 minutes to post anything, using Chrome, editing is instantaneous, so in some cases I have edited my original post because of the PITA unresponsive script on Windows 10 Chrome, FYI it does the same thing using Chrome on windows 7 and also on Firefox. So it is changes to the site. In your case hit continue, in my case I hit wait.
post #3 of 14 (permalink) Old 08-07-2016, 09:12 PM
saddlebag's Avatar
Write posts 1/3 as long.
saddlebag is offline
post #4 of 14 (permalink) Old 08-07-2016, 09:33 PM
Don't see it on my tablet.
This site is full of spyware.
post #5 of 14 (permalink) Old 08-09-2016, 11:40 AM
Administrator
Hey there,
Unresponsive scripts are extremely common issues with members and moderators across all boards. these issues have a number of troubleshooting ways to fix it.
Shockwave is usually a pretty big factor in this, along with outdated browsers, flash, java, and not having enough processing power on whatever device you are accessing the board with.
Below are common fixes to fix this. video ad's can be turned to "click to play" instead of autplaying. and a few other fixes can be applied as well to streamline your browser experience.
If it is still an issue, it could be a rogue Ad with bad stuff attached potentially.
keep in mind a number of things can cause this, not just the back end. but could be extensions, plugins, malware, etc.
here is the more common fixes for this:
- shockwave being unstable. disabling or deleting this could help
- updating your flash and java to the lastest update
- any rogue extensions that "auto installed" on your browser without you knowing.
- malware or spyware has piggybacked your browser
- hardware acceleration could be incompatible with your system in general.
- Rogue Ad causing the issue as well.
- Cookies and cache are outdated and need to be cleaned
- temporary internet files on your back end are flooding and fighting for use. doing a disk clean up could help as well.
You can read more about possible fixes below here. These fixes can also apply to chrome, but would be in different areas.
I hope that helps.
- https://support.mozilla.org/en-US/kb...ponsive-script
- https://support.mozilla.org/en-US/kb/troubleshoot-extensions-themes-to-fix-problems
- https://support.mozilla.org/en-US/kb...s-fix-problems
- Unresponsive Script Warning - MozillaZine Knowledge Base
~Shane
KawiMan is offline
post #6 of 14 (permalink) Old 09-22-2016, 10:42 AM
Hijacking Thread/ No Further Replies Under Unresponsive script
Yes That is the message I want to read first thing in the morning. First , it would appear that all indicated solutions point to the user as being the problem, including suggested viruses etc. They are all oriented to Mozilla, Chrome has the same problem but worse.
I said it before, this all happened after the password change, I got extremely frustrated trying to change all kinds of settings on my Browser's, to solve a problem that I run into only on this site, maybe I should throw in the towel and move on to the UK Versys site, which I have 0 problem in posting or logging in. I frequently get invalid redirect when logging in, hit back and there I am logged in on this site.
So I edited this post as in my post #9 I explain the latest development , only took 1 1/2 months to solve. I could have done like some and just left this forum, and because I didn't I felt it appropriate to leave as is what I posted, as a reminder to Administration, without us posters, you don't have a forum, posting adds has been discussed , much earlier discussion about it, pay attention!
post #7 of 14 (permalink) Old 09-22-2016, 10:51 AM
Fly-Sig's Avatar
Safari can get pretty slow on this site. Ad Blocker can help prevent freeze ups but it also slows down loading pages. Lots and lots of crap being pushed to the computer. My adblocker is showing 29 blocked ads just loading this page.
I'm on another forum hosted by the same group and the problems are the same or even worse. Numerous long time members over there are openly discussing leaving the forum. Whoever owns this platform is obviously trying hard to monetize it, which is fine, but they are driving away their membership.
Fly-Sig is offline
post #8 of 14 (permalink) Old 09-22-2016, 11:07 AM
Solved Chrome
Yes I got 18 blocked adds, this morning I was basically told to take a hike, simply because of adding a comment on a log in problem, suggested that no more postings under this thread indicated the problem was solved. On Chrome I went in and cleared browsing history/cookies from beginning of time, same disabled hardware accelerator and I notice the drag and drop has been disabled in the log in thread. Which probably was the root cause of unresponsive script, about time !
post #9 of 14 (permalink) Old 09-22-2016, 11:38 AM
Browser Chrome & Mozilla Quoting now 100% back to normal
I have now enabled use hardware acceleration when possible, on both Mozilla and Chrome,cleared cache and cookies from beginning of time in Chrome. No more unresponsive script since drag and drop has been disabled--basically it was this site all along
post #10 of 14 (permalink) Old 09-23-2016, 10:13 AM
Administrator
Should all be working now. We disabled a plugin that seems to be causing these script errors.
Lee
KawiMan is offline
post #11 of 14 (permalink) Old 09-23-2016, 04:37 PM Thread Starter
Lee
Lee - looks like you succeeded!
Thanks,
post #12 of 14 (permalink) Old 09-26-2016, 01:22 PM
Administrator
Thanks,
Glad to hear!
Any other instances of this happening with you or anyone else since the plugin was disabled?
Thanks,
- JB
KawiMan is offline
post #13 of 14 (permalink) Old 09-27-2016, 04:43 PM
Works like before Password change
Glad to hear!
Thanks,
- JB
All is good, thanks for acknowledging it was a site problem. Any remaining issues with notification or logging in are minor and easily worked around.
post #14 of 14 (permalink) Old 09-28-2016, 03:18 PM
Administrator
If you're having any issues with notifications and logging in, let us know, and we can help.
Had you already created a thread on those issues I can look into?
Thanks,
- Jb
KawiMan is offline
Human Verification
