Replacement sprockets 2015+ - Kawasaki Versys Forum
 4Likes
  • 1 Post By Trbl
  • 1 Post By fasteddiecopeman
  • 1 Post By trialsguy
post #1 of 11 (permalink) Old 04-29-2017, 11:24 AM Thread Starter
Has anyone replaced both sprockets and chain on a 2015+ plus yet?
If so what brands did you use and where did you get them.
I am about to turn 17,000 miles on my 2015 and I am looking
to swap mine out before I zip to Bar Harbor for a lobster
next month. Any help would be great!!
Cheers
Woodman
woodyburns is offline
post #2 of 11 (permalink) Old 04-29-2017, 05:24 PM
Just the regular "JT" or "Sun Star" sprockets, same as on the Gen 1 and 2 Vs.
post #3 of 11 (permalink) Old 04-29-2017, 06:29 PM
quexpress's Avatar
On average, how long do sprockets usually last on the Versys 650 before needing to be replaced?
I still have a full deck.
I just shuffle slower.
Note: I have no time to waste because Iím older at this moment than Iíve ever been before,
Ö and itís the youngest Iím ever going to get.
quexpress is offline
post #4 of 11 (permalink) Old 04-29-2017, 07:46 PM
bigaussie's Avatar
Depends if you clean and lube your chain religiously, keep it properly tensioned and aligned, etc.
bigaussie is offline
post #5 of 11 (permalink) Old 04-30-2017, 02:45 PM
Original chain and sprockets will typically last 15 to 20,000 miles. The original chain is "OK" but there are better aftermarket chains that will get you in the 25,000 range with similar steel sprockets.
quexpress likes this.
Trbl is offline
post #6 of 11 (permalink) Old 04-30-2017, 03:08 PM
Originally Posted by Trbl View Post
...The original chain is "OK" but there are better aftermarket chains that will get you in the 25,000 range with similar steel sprockets.
The OEM chain on my '08 V lasted about 56,000 MILES on ONLY WD40 to clean and lube it. Changed countershaft sprockets at around 29K miles, rear one same time I replaced the chain.
Here's a link to the thread I posted about the 'change'....
Changing my ORIGINAL chain and rear sprocket
post #7 of 11 (permalink) Old 04-30-2017, 08:39 PM
The steel counter shaft sprockets are quite a bit louder than the MaKaw damped ones. I installed a D.I.D. x ring with JT sprockets in the kit at 11k miles. The bike had already had at least the rear sprocket and the chain replaced. Apparently chain maintenance was not in the previous owners repertoire.
Yeah, if you want true ram air tuning, you better be willing to ram some air! (SiSF)
'15 KLE650LT
'98 KLR650
And most of Canada too, eh?
SteveJ is offline
post #8 of 11 (permalink) Old 05-01-2017, 03:19 PM
Originally Posted by SteveJ View Post
The steel counter shaft sprockets are quite a bit louder than the MaKaw damped ones....
I wear ear-plugs, so I never noticed....
whiting57 likes this.
post #9 of 11 (permalink) Old 05-01-2017, 07:04 PM
whiting57's Avatar
While my bike is brand new, I changed the front out immediately from a 15 tooth to a 16 tooth @ 50 kms ( 30 miles) , this was primarily to correct the speedo with a bonus slight drop in the rpm's .... the rear and chain remained the same.
And as I flipped into 6th, I could not remember a damn thing she said ....
whiting57 is offline
post #10 of 11 (permalink) Old 05-02-2017, 11:09 AM
My '08 V has 30,000 miles on it with the original stock chain and rear sprocket. I replaced the countershaft sprocket a couple of years ago. I expect to get another 10,000 miles before replacing the chain and sprockets.
trialsguy is offline
post #11 of 11 (permalink) Old 05-02-2017, 03:49 PM
quexpress's Avatar
Human Verification
