Oil issue... - Page 2 - Kawasaki Versys Forum
 13Likes
post #21 of 32 (permalink) Old 03-14-2017, 11:11 AM
Mobil1 automobile 15w-50? i thought you are not suppose to use car oil with a wet clutch due to friction modifiers causing clutch slippage,
silviefox - when I had a Bandit 1200 (OVER 100HP...!), after a back-and-forth w/ one of the forum members who drag-raced HIS, I started using M1 10w-30 and NEVER had a clutch issue! BTW - the 10w-30 HAS friction modifiers while the 15w-50 does NOT.
quexpress likes this.
post #22 of 32 (permalink) Old 03-14-2017, 05:38 PM
quexpress's Avatar
This has been discussed MANY times on numerous motorcycle forums for the past (at least) 17 years.
Glance at the round logo at the rear of the oil container. If there is no reference to friction modifiers or to energy conserving, there is no problem using that oil in your motorcycle.
FWIW I have been using these types of oils in my motorcycles for the past 15 years without any oil related problem whatsoever.
Note: Oils rated CI-4 are OK in our bikes.
I still have a full deck.
I just shuffle slower.
Note: I have no time to waste because Iím older at this moment than Iíve ever been before,
Ö and itís the youngest Iím ever going to get.
quexpress is offline
post #23 of 32 (permalink) Old 03-14-2017, 06:20 PM
I've been using M1 15w50 in my 03 harley since it was new. It has over 90,000 miles on it now, and the clutch has never been replaced, nor has it ever showed signs of slipping. I have adjusted it every 20,000 miles, and just replaced the original clutch cable last week. Not broken, just getting hard to pull, and lubrication didn't help. I have used M1 in all my harleys. I used Rotella for my first oil change on my Versys, and have no problems. I will probably use M1 15w50 in it from now on. I live in south Ms. and it is hot and humid here in the summer time.
Skypilot 69 is online now
post #24 of 32 (permalink) Old 03-15-2017, 01:07 AM
Motul 4T 7100; 10W40 in both my bikes. Good stuff, lovely red color.
kawafornia is offline
post #25 of 32 (permalink) Old 03-15-2017, 07:59 PM
BelRay is an excellent oil and 10W50 is no problem either. Your problem is just cold oil that hasn't yet been chopped to **** by your transmission.
SlowIsSmooth is online now
post #26 of 32 (permalink) Old 03-16-2017, 04:01 AM Thread Starter
ash
I will attend to that as soon as the weather get a little bit warmer...
ash is offline
post #27 of 32 (permalink) Old 03-16-2017, 09:12 AM
I feel that agonising over the oil type and brand is a waste of time. As long as the specs on the oil and the proper weight as per the manual are followed the brand doesn't matter much. I put over 200,000 km on a Concours using mostly regular oil. I put synthetic in it for a long trip (20000 km) and never changed the oil. I had it analysed when I finally changed it and the oil had 20% useful life remaining. That bike never used any oil and I never had engine wear or clutch problems.
In my V I use non-synthetic 10W40 motorcycle oil from Motomaster, a Canadian Tire brand. I need to be frugal and synthetic oil is very expensive. I look for my oil to come on sale and then buy 6-8 quarts (946 ml).
onewizard, DaveC and quexpress like this.
Smiley is offline
post #28 of 32 (permalink) Old 03-16-2017, 09:30 AM Thread Starter
ash
In my country the BelRay EXS is 54$ 4 liters oil filter included...so it's not so expensive..
ash is offline
post #29 of 32 (permalink) Old 03-16-2017, 12:03 PM
Originally Posted by Smiley View Post
...In my V I use non-synthetic 10W40 motorcycle oil from Motomaster, a Canadian Tire brand. I need to be frugal and synthetic oil is very expensive. I look for my oil to come on sale and then buy 6-8 quarts (946 ml).
In Canada I buy my oil at either Canadian Tire or Walmart, usually in the 5L plastic jugs of Mobil1. In BC they do NOT seem to carry the 15w-50 that I like to use, so I have friends bringing back a jug in their motorhome, but in Ontario you MIGHT get it...?
post #30 of 32 (permalink) Old 03-16-2017, 12:16 PM
Mobil 1 15 / 50
It was one of those fluky things, on sale at Canadian Tire last year, if it happens again I will post it, it was the same price as regular oil when on sale.
post #31 of 32 (permalink) Old 04-06-2017, 09:59 AM
devintlu's Avatar
Originally Posted by ash View Post
Guys, what brand and type of oil do you usually use?
I've just had my oil change and put in BelRay EXS 10w-50 full synthetic...the versys doesn't seem to like it...if i don't let the bike warm up to 60į at least the gear changes are ruff ...like there is no oil and i really have to pull up on the lever to engage 2nd...after the bike gets warm all shifts are really smooth...
Anybody else experience this?
I use the motorcycle specific Mobile 1 (10W-40) for my Gen 1 Versys and it seems to work really well.
Devin Lu - 2009 Versys
devintlu is offline
post #32 of 32 (permalink) Old 04-06-2017, 10:06 AM Thread Starter
ash
I've switched to semi sythetic BelRay EXP and it seema to be better...the original oil from kawasaki was semi synthetic (as they call it, synthetic technology).
ash is offline
Human Verification
