dummy's guide to lowering the front end? - Kawasaki Versys Forum
 3Likes
  • 1 Post By kballowe
  • 1 Post By Brad906
  • 1 Post By Brad906
post #1 of 5 (permalink) Old 03-24-2017, 07:11 PM Thread Starter
Bike: 2017 650 LT
Question: how to lower the front end after installing lowering block in the rear?
I’m a rookie when it comes to wrenchin’ so take it easy on me… but how do you “set up” the bike to lower the front end after installing Motowerk’s lowering block in the rear?
Motowerk’s instructions:
https://cdn.shopify.com/s/files/1/11...57159767210442
Do you have the bike on the side stand?
Do you support the bike via the handlebars?
Use a paddock rear stand?
Must you have no weight on the front wheel?
How do you raise one side at a time if the bike has weight on the front wheel? Will the individual forks raise separately?
I have searched including youtube but can’t find anything to give basic information (pictures or video) on how to lower the front end. All the videos I have seen say “loosen this bolt, loosen that bolt, and lower the front.” Never do they show it actually being done.
My apologies if might seem basic to some but I don’t want to jack my new Versys by dropping the front end down to the wheel.
Thanks for any help.
2017 Versys 650 LT -- Titanium
Mods: Debadged, Moto Werk lowering kit
407guy is offline
post #2 of 5 (permalink) Old 03-25-2017, 06:58 AM
kballowe's Avatar
Just do one side at a time - but make sure the bike doesn't fall over.
It helps to have another person spot you - or somehow secure the bike while you're wrenching on the front end.
Works for me.
407guy likes this.
kballowe is offline
post #3 of 5 (permalink) Old 03-25-2017, 11:54 AM
As mentioned already.....barring proper stands, don't try it alone!
One side at a time!! Measure your desired drop on the tube, below the lower triple clamp. Mark it, apply tape or a hose clamp. Loosen all but one pinch bolt while a strong helper unweights the front wheel pulling towards/against the side stand. Stand down of course. Loosen the last bolt -slowly- while applying a bit of weight for the fork to slide up in the clamp. When in position, snug that bolt and the next most accessible. Finalize torque on all bolts...Repeat!
Not alway perfect to avoid binding but if done equally it's as good as it left the assembly line!
407guy likes this.
Brad906 is offline
post #4 of 5 (permalink) Old 03-25-2017, 05:51 PM Thread Starter
So attempt to have more pressure/weight on the fork you are not moving? Am I understanding this towards/against method correctly?
Thanks.
407guy is offline
post #5 of 5 (permalink) Old 03-25-2017, 11:26 PM
Just lighten the front as if trying to lift it off the floor using the stand as a third wheel. Once bolts are loose, let the weight come back to the wheel,-slowly- pushing the tube upward. Leaving one side tight keeps the front from collapsing fully.
407guy likes this.
Brad906 is offline
Human Verification
