LED Driving Light Install (from ADVrider) - Page 2 - Kawasaki Versys Forum
 5Likes
post #21 of 67 (permalink) Old 03-22-2011, 03:33 PM
offcamber's Avatar
Originally Posted by camaroz1985 View Post
Are the old ones still available?
I think he is phasing the 10 and 24 watt and going with a 30 and 44 watt.
http://stores.intuitwebsites.com/hst...StoreFront.bok
offcamber is offline
post #22 of 67 (permalink) Old 04-29-2011, 11:39 PM
Mchustlr's Avatar
Originally Posted by scotty_h View Post
Quick update guys on my lights that came in from Jon at ADV Monster. He has recently upgraded his lights to a 4 LED 2000 Lumen setup which I missed out on, but I do have his 24 watt 3 bulb system. Let me tell you... night driving is a different ballgame. I installed with a set of Pingel Clamps. I have been looking for a good place to secure these as I was not too keen on mounting them on the upper fairing or the lower front fender (in case of drops) So, I have ended up with them here.
Yikes! kinda dirty. Probably add plastic thread caps to the top soon.
Hope this inspires.
Where did you get the fork clamps??
Mchustlr is offline
post #23 of 67 (permalink) Old 04-30-2011, 09:21 PM
I think these are the ones that Scotty used:
http://www.pingelonline.com/stabiliz...be_bracket.htm
Steve
lonerockz is offline
post #24 of 67 (permalink) Old 11-18-2011, 11:21 AM
camaroz1985's Avatar
I finally got around to installing these. They were great for a night, then the next I turned them on, then off, and now they won't come back on. Checked the fuse and it is good, so now I need to start tracing things back. I'm leaning toward the switch. I got the one they sell on the ADV Monster site, and it doesn't seem to click like it did before.
camaroz1985 is offline
post #25 of 67 (permalink) Old 11-23-2011, 10:58 AM
Wiring is all good. I read on ADV that HID lights can kill the LED driving lights. I hope that didn't happen with mine.
post #26 of 67 (permalink) Old 12-05-2012, 01:55 AM
andrewhtf's Avatar
Reviving an old thread.
How so? I do intend to use this in addition to a hid setup.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #27 of 67 (permalink) Old 12-05-2012, 12:01 PM
I think someone said it was the inrush current spike. I have not been able to confirm that, but my lights both stopped working. I haven't taken them apart yet to trace down any burnt components or anything yet.
post #28 of 67 (permalink) Old 12-05-2012, 12:50 PM
I've got the 30 watt variety. VERY bright, wow! Mine are mounted much the same as the OP's and I did a fairly quick swap out of the Walmart lights I'd had on (and replaced under warranty several times...they are junk, unfortunately).
One issue I had is I needed to replace the supplied small pan machine screws that hold the bracket in place and allow side to side light aiming. The supplied screw heads looked Phillips but did not cleanly engage with any of about two dozen Phillips screw drivers I have, nor did they work with JIS screwdrivers (I have 4 of those). Just couldn't get enough torque on the screw without the screwdriver slipping out. I though I had tightened them enough to hold the lights tightly in place but when I came home from a ride on Monday the right light was pointing way off to the right. The left one was still pointing straight but I was able to move it by hand easily. A trip to Lowe's and $4 solved the problem with 6-32 x 1 1/4 stainless machine screws that work with screwdrivers and nylon insert nuts to keep things from loosening up. Nice and snug now.
Ride. Good.
2003 ST1300ABS
2008 Versys
Reading Material:
post #29 of 67 (permalink) Old 12-06-2012, 09:23 PM
andrewhtf's Avatar
I am thinking of adding separate on/off switch for both the LED and HID.
Both OFF when starting the bike. As and when the bike idles fine and ready to go, HID headlamp is flipped ON (the law in my place here requires the headlamp to be constantly on). As and when the situation requires (night riding), then flick the LED ON, while at the same time i have the option to either keep the HID ON or OFF.
Just trying to minimise the load on the power coils. There has been a few cases of versys coils burnt in my country. They're 2011 bikes.
Up next :
post #30 of 67 (permalink) Old 12-06-2012, 09:27 PM
andrewhtf's Avatar
i'd prefer to mount them on the radiator shrouds, so that it wont be a costly affair should my bike decides to have a rest on its sides.
Thanks for the tip on the phillip head screw though.
Up next :
post #31 of 67 (permalink) Old 12-07-2012, 06:22 PM
naples_kev's Avatar
Nice idea. I just did some searching and found the below lights for $16 shipped for the set.
1500lum 12V 2 Pcs 3 LED High Power Auxiliary Spot Light for Motor Bike ATV Jeep
http://www.neewer.com/1500lum-12v-2-...p_p_13901.html
They look identical. For $16 ill take a chance on them. Just will take a few weeks to show up.
What do y'll think?
naples_kev is offline
post #32 of 67 (permalink) Old 12-08-2012, 12:25 PM
Just ordered TWO sets, for 'BIG RED' and 'the Green Hornet'!
post #33 of 67 (permalink) Old 12-09-2012, 04:36 AM
andrewhtf's Avatar
What do y'll think?
Yeap, those 1500/1600 lumens led lights came before the 3000 led lights. Those 3000s were recently introduced this year.
While the 1500/1600 lumens are good enough for roadside illumination but after seeing the side by side comparison of both lights, i was like, oh what the hell i'll just blast them till kingdom come.
Up next :
post #34 of 67 (permalink) Old 04-01-2013, 04:44 PM
ADVMonster
Just filled out an order for the ADVmonster lights.....they are priced at $45 a piece....shipping came out to $39.....that doesn't seem right. Is there a coupon code for the site?
Choppastyle
Life is short, a midget told me that.
Choppastyle is offline
post #35 of 67 (permalink) Old 04-02-2013, 10:18 AM
G19Tony's Avatar
Choppastyle
The shipping will change later in the process. I just received my second set the other day. They will be going on the TU250.
I have the dimmer on the V.
Jaes1 likes this.
G19Tony is offline
post #36 of 67 (permalink) Old 04-02-2013, 01:25 PM
shipping
You're right....it changed at step 3 to $9....much better and ordered. I wonder how many people have been scared away by original posted fee
Look forward to giving these a go
Thank you,
Choppastyle
post #37 of 67 (permalink) Old 04-06-2013, 08:57 PM
Installed Lights Today
Installed the lights today. I bought a toggle switch but decided to wire them directly to my fuse box. I went to the "Light" fuse so they come on and off with the bike. Works perfect
Thank you,
Choppastyle
post #38 of 67 (permalink) Old 04-06-2013, 09:09 PM
Zatx's Avatar
What are you using to mount the lights in that spot?
Zatx is offline
post #39 of 67 (permalink) Old 04-07-2013, 11:24 AM
andrewhtf's Avatar
Zatx, that's the sw-motech hawk light mount. Mine's the same.
Up next :
post #40 of 67 (permalink) Old 04-07-2013, 05:04 PM
Davy F's Avatar
I just drilled through the radiator cowling and used cushioned washers to sandwich the bolt and spread the load. So far, no problems and both lights are very steady. I preferred this to buying the SW-Motech mounts as, well, I think they are not that good looking a solution.
For 5 watts power, they're pretty damn bright.
And very neat.
Nice switch too.
Davy F is offline
Human Verification
