Dash pic thread - Please post pics of your setup - Page 2 - Kawasaki Versys Forum
 39Likes
post #21 of 75 (permalink) Old 01-06-2017, 10:33 AM
quexpress's Avatar
Originally Posted by Joey Rocket Films View Post
Pretty badass set up man. Thanks for sharing that.
You're most welcome! Thanks!
What's up with the headlight modular?
Sorry. I don't understand your question. Could you re-word it please?
I still have a full deck.
I just shuffle slower.
Note: I have no time to waste because I’m older at this moment than I’ve ever been before,
… and it’s the youngest I’m ever going to get.
quexpress is offline
post #22 of 75 (permalink) Old 01-06-2017, 10:33 AM Thread Starter
Joey Rocket Films's Avatar
So glad I finally have one of these! No more searching for 7th gear! Of all my years of riding I can't believe I finally grabbed one of these. Slacker... really easy plug and play
Best $45 ever
quexpress likes this.
Ride it like you stole it but also like you wanna be able to ride it to work the next day
My V - Z.A.B. 2.0
Joey Rocket Films is offline
post #23 of 75 (permalink) Old 01-06-2017, 10:34 AM Thread Starter
What is it? What does it do?
My V - Z.A.B. 2.0
post #24 of 75 (permalink) Old 01-06-2017, 10:46 AM
quexpress's Avatar
"Motorcycle headlight modulators rapidly flash the motorcycle’s headlight at 240 (plus or minus 40) cycles per minute.
This is designed to attract the attention of oncoming drivers."
Click on the above link for more details.
post #25 of 75 (permalink) Old 01-06-2017, 11:05 AM Thread Starter
Nice, thanks. I'll have to add an image like yours when I'm all done.
My V - Z.A.B. 2.0
post #26 of 75 (permalink) Old 01-11-2017, 05:28 PM Thread Starter
Thats the control button for the Koso Apollo Heated Grips which are awesome ...https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Got my grips. Can you give me some insight on where to run the power to? Do you have any pics? I'm. It great with electrical ****.
My V - Z.A.B. 2.0
post #27 of 75 (permalink) Old 01-11-2017, 06:01 PM
For me it was easy i have a Admore Wiring Harness that i took off my FJR cut the white ends off then used post-tap to connect to the V-1000 wires i needed. I wanted them on a switched line so i ran the power wire from the grips to the wiring harness thats connected to the Tail Light Wire. I also have my GPS wire connected there also. Then i attached the ground wire from the grips to a bolt next to the back brake fluid reservoir. The GPS & Heated Grips power wire is connected to the Blue/Red wire terminal.
Electrical by weljo2001, on Flickr
post #28 of 75 (permalink) Old 01-11-2017, 06:10 PM
Not sure what the color of the Tail Light wire is on your model. But if you want it switched connect the power wire from the grips to the tail light wire or any other switched wire. Then take the ground wire from the grips and use any bolt on the frame to use. If you don't want it switched just attach the Grip wires to the battery. Heres what i used to tap into the wires..https://www.amazon.com/Lockitt-POSI-...words=posi+tap
Joey Rocket Films likes this.
post #29 of 75 (permalink) Old 01-11-2017, 06:14 PM Thread Starter
Thanks! I think what I'm going to do is just wire them straight to the battery. Normally I wouldn't take that chance because I can be forgetful but we're talking about a major source of heat on my hands with a well lit led and this "This system will detect if the battery voltage is too low and will automatically shut down the heated grips in order to make sure the rider have enough power to start the engine or use the motorcycle." I'm thinking I'll be all set and I can always rewire if it becomes an issue. Thoughts?
weljo2001 likes this.
My V - Z.A.B. 2.0
post #30 of 75 (permalink) Old 01-11-2017, 06:28 PM
Thats what i would have done if i did't have the harness already hooked up.
post #31 of 75 (permalink) Old 01-11-2017, 07:05 PM Thread Starter
Ok glad to hear that wasn't a bad idea. Now I just need to figure out how I'm gonna wire my Bluetooth speakers system.
My V - Z.A.B. 2.0
post #32 of 75 (permalink) Old 01-12-2017, 01:14 PM
I would wire it so that they are OFF when the bike's OFF. DON'T forget that you HARM your battery whenever you run it to minimums, and it will only do that a finite number of times...!
post #33 of 75 (permalink) Old 01-12-2017, 01:15 PM
DON'T forget that you HARM your battery whenever you run it to minimums, and it will only do that a finite number of times, THEN you get to buy a new one...!
post #34 of 75 (permalink) Old 01-12-2017, 02:20 PM Thread Starter
Run into minimums?
My V - Z.A.B. 2.0
post #35 of 75 (permalink) Old 01-12-2017, 11:15 PM
Tomasama's Avatar
I neeeeeeed this... any how to videos around ?
Nevermind, I found your write up!
West coast is best coast!
My motovlog
Tomasama is offline
post #36 of 75 (permalink) Old 01-13-2017, 01:10 PM
Mine
Just finished adding a 12 volt marine outlet and a nifty volt meter.
AlaskaJeff is online now
post #37 of 75 (permalink) Old 01-13-2017, 01:14 PM Thread Starter
[QUOTE=AlaskaJeff;1317849]Just finished adding a 12 volt marine outlet and a nifty volt meter.
Very nice! Thanks for sharing!
My V - Z.A.B. 2.0
post #38 of 75 (permalink) Old 01-13-2017, 02:40 PM
Run into minimums?....
Let it 'run-down' (discharge) to the point it won't power your bike anymore.
post #39 of 75 (permalink) Old 01-21-2017, 02:43 AM
93TigerBill's Avatar
Cockpit > aka “Farkled to Death”
My 2010 Versys 650 ABS, now with 50,000 km; [my avatar says "93TigerBill", 'cos I also have a 1993 Triumph Tiger, relegated to a "show pony"]....
First Pic, L to R:
- Handguards, BarkBuster ‘Storm’;
- Heated Grips, Oxford (Replacement Controller on order); (*)
- PTT switch for UHF Radio;
- Mirror Extenders (Home-Made);
- Aux. Lights Switch; (*)
- LHS Fairing Panel: Autocomm cable; (*)
- LHS Fairing Panel: (hidden) SAE Connector for Heated Jacket; (*)
- GPS #1 (no maps) – Garmin eTrex “Data Logger”;
- UHF Radio 80 ch 5W IP67 with separate Aerial (left front of windscreen);
- GPS #2 (with maps) – ALDI special, IP67, power socket on LHS dash;
- SPOT II tracker/”EPIRB”;
- (behind SPOT) On Dash RHS – Voltmeter; (*)
- RHS Grip – OmniCruise Throttle Lock;
- Tank Ring for Tank Bag.
Second Pic:
- 2x 70W LED’s, Spot & Spread, with brace between;
- 2x 10W LED’s Spots – Denali/VisionX;
o Note: Both sets controlled by Aux Light Switch (above) and a single 5-pin Relay, triggered by Hi-Beam.
Not Shown:
- Stebel Nautilus Air Horn; (*)
- Radiator Guard – RadGuard;
- SW-MoTech:
o CrashBars;
o Engine Guard/Skid Plate;
o CentreStand;
o Side Racks (removable) with Pelican-Type Cases & Tool Tubes;
o Alu-Rack (yes, they can be fitted with side cases!);
- Speedy’s:
o Sidestand Foot;
o Footpeg Lowering Kit;
o Handlebar Risers;
o (Suspension Lowering Kit - removed to fit CentreStand).
(*) All powered through an Eastern Beaver PC-8 Fuse Block.
FarRider#89; IBA#45911; Versys ABS 2015; Triumph Tiger 900 ('93).
Newcastle Australia
93TigerBill is offline
post #40 of 75 (permalink) Old 01-21-2017, 10:07 AM
Wow - serious comm support, nice!
A couple questions if I may:
1) what mounting system are you using up near the windshield - assuming home built, specifically how are you mounting it? I'm pondering fastening to the windshield mounting points, not sure if the vibration becomes an issue.
2) What are your thoughts on the SPOT, have you ever had to use it? Do you have issues with connectivity?
Much appreciated!
PHX_Joe is offline
Human Verification
