New Vacuum Hose Mod - Page 17 - Kawasaki Versys Forum
Modifications - Performance Discuss aftermarket and DIY performance modifications
Sponsored by: LeoVince USA
 1Likes
post #321 of 374 (permalink) Old 06-11-2012, 11:34 PM Thread Starter
I posted some time ago #243, what I found was engine braking spewed fuel out like when first starting bike. My fuel mileage dropped drastically, so I changed it back. What made a more significant difference was adjusting my TPS as was suggested by Invader in a previous thread. Like a different bike, I have driven at 2500 to 3000 RPM in 3RD gear, and it is very smooth.
How much of an adjustment did you give your main throttle sensor (TPS)? Is your main throttle sensor voltage output at WOT still withing spec?
post #322 of 374 (permalink) Old 06-12-2012, 10:45 PM
Normally once I solve a problem I forget it, in this case it has been over two years, I have no problem keeping up with my son's 919 Honda, and I get much better gas mileage.
Since it isn't a problem, I really don't have the patience to look in the manual to find out were to measure and what readings I should get. However out of curiosity and for the others that participate on this forum, I would be willing to check this, if you could provide some direction.
post #323 of 374 (permalink) Old 06-12-2012, 11:56 PM
BAMF's Avatar
i just switched from the version where the tube coming from the sensor T's off into both of the ports
to
the version where the tube goes to the left most port and the other two ports are connected.
What I noticed right away was, much better low rev smoothness and it wasnt quite as torque'y (which I which wasnt true, but the first setup was jerky)
1997 KLR 650
2011 Halle-friggin-leuya Versys
BAMF is offline
post #324 of 374 (permalink) Old 06-13-2012, 09:28 AM Thread Starter
It involves measuring main throttle voltage output at WOT, as directed in service manual.
TPS Adjustment
You're simply looking at rotating main throttle sensor clockwise just enough to see a slight offset at its green reference mark.
post #325 of 374 (permalink) Old 08-06-2012, 03:59 AM
easy 78's Avatar
so, it appears now that Kawasaki has adopted this mod as a standard setup for 2012 ER6n, Ninja 650 and probably Versys too. CA models
this is a picture from a 2012 Ninja 650R during the par valve blocking procedure, and everything is still stock.
curious as to where the hose coming from the T goes to...
easy 78 is offline
post #326 of 374 (permalink) Old 08-06-2012, 04:08 AM Thread Starter
Wow... I wonder where the T'd hose goes to.
post #327 of 374 (permalink) Old 08-06-2012, 06:49 AM
Charcoal canister?
I bought my 11 new with zero miles. It ran well. Throttle was herkity jerkity but I got used to it and I understand how it works.
Then I set the TPS to the max Idle voltage at 1350 RPM. Bike ran MUCH better. Herkity Jerkity almost gone.
I tried the T mod of the two throttle bodies for a couple days. I got a lazy throttle and not as much low end response, so I put it back to stock.
I think if I had done the T mod of the hoses before setting the TPS it would have been different.
Vacuum hoses are stock, TPS is at max spec for idle. Bike runs great gets 49 mpg.
It was worth trying and looks like a good idea, just not for me.
YMMV!
David
David RSparky3 is offline
post #328 of 374 (permalink) Old 08-06-2012, 07:01 AM Thread Starter
T-mod? What works well is a simple 6" (15 cm) long, 1/8" (3 mm) ID vacuum hose on TB vacuum fittings.
post #329 of 374 (permalink) Old 11-14-2012, 08:45 AM
Motopreserve's Avatar
Confirmation of method
Hey folks,
I have had this thread bookmarked since first getting my Versys, and will be attempting the mod today, since I'll have the bike half-apart to change spark plugs and clean the air filter.
Can someone please confirm that the diagram below is the best option. I have seen talk of other methods, but they all seem to lead back to this setup. I looked on the french site as well, and this seemed to be the method used (as best I could tell, without translation).
It seems I need to couple the carb sync fittings together using hose and T connector, and also cut the original hose coming from the IAP (far left fitting if sitting on the bike), inserting a T connector, which the single end of the carb sync T connector inserts into. Sound right?
Thanks!
**'2011 Versys, '75 Honda CL360 cafe project, '76 CB 550, '09 Husky TE610**
Motopreserve is offline
post #330 of 374 (permalink) Old 11-14-2012, 09:40 AM
+1 on what Invader recommends. Used it for about 20,000 miles with no problems. And, it's simpler to implement.
ScottyNeal is offline
post #331 of 374 (permalink) Old 11-14-2012, 09:45 AM
Thanks Scotty. Just to confirm - the diagram has what invader recommends??? That's the simplest, final call?
Appreciate the help.
post #332 of 374 (permalink) Old 11-14-2012, 10:45 AM
moflow's Avatar
The simple set up that I think is being referred to is this one:
New Vacuum Hose Mod
I too have used this set up for 15 000 km and it has definitively made the bike much smoother at low rpm and got rid of the "herky-jerky" throttle.
I've been running a modified Cherry Bomb muffler, blocked off the PAR valve and have had no "popping" on decel with this mod.
FWIW - I just finished a 445mi run where I averaged on the highway around 5.5K rpm (70 mph) and got 48mi\gal. I've got stock gearing and she's a very smooth runner. Still makes me smile all the time.
moflow is offline
post #333 of 374 (permalink) Old 11-14-2012, 11:05 AM
Ok, this is very different than the one in the first post of this thread. This skips the carb sync port on the left body altogether.
I'll try this and see if it works.
Thanks.
post #334 of 374 (permalink) Old 11-14-2012, 02:15 PM
The problem is you do not want a unrestricted vacuum connection between throttle bodies. It would have been a lot simpler for Kawi to do this than implement the more complex sync connection between the two. The reason for this is when one cyl is drawing air it will lower the vacuum in the adjacent cyl with a vacuum pulse. This makes the mixture richer but reduces performance slightly. If Kawi did not care as much about performance they would have used a much cheaper single throttle body that would have equalized vacuum like this. The reason for the dual throttle bodies is so the drawing of one cyl does not effect the other, also the large air box helps with this too - the volume of the air box is several times the capacity of both cyl.
I would like to see someone dyno their bike before and after this mod.
post #335 of 374 (permalink) Old 11-14-2012, 02:20 PM
Sorry twowheels, are you saying there is a problem with the way I just set it up (method in the linked post - which bypasses the left sync port)??? Or just filling me in on the how/what/why of what this mod does, or why it's better with it?
Either way, I appreciate the post. . I'm just trying to get a definitive answer to what the common consensus is for the best method.
post #336 of 374 (permalink) Old 11-14-2012, 03:09 PM
duffyduck1's Avatar
Hi,
the guy that invented this mod at first time connected left and right body by a line.
That is mod 1 (I made on my V).
After he made an evolution that is the diagram that you posted.
Your diagram is definitively ok.
Sorry for my bad english, I'm learning. Please report my errors
Kawasaki Versys 07 Orange - Aprilia Pegaso 96 Blue
Suzuki DR 350 91
duffyduck1 is offline
post #337 of 374 (permalink) Old 11-14-2012, 03:26 PM
AHHHHHHHHHHHHH!!!!!!!!!!!
OK folks. While I really appreciate all the help this forum provides, this is one of those times that each post gets me more and more confused.
The very first post of this thread contains the mod, as explained by Invader. The diagram I posted above is an exact replica of that first post (photo #3). My plan was to do exactly as Invader and the diagram described.
But after reading 11 pages of posts in this thread, it seemed that there may have been a change of heart - a more simpler way of doing it. MoFlow confirmed this by linking HERE
So I just completed the mod as described in the photo (also by invader) in the link above, NOT like the diagram I posted. That "NEW" way of doing it doesn't tie the two bodies together, then link it into the IAP line with a second T connector. It simply puts a line between IAP port on the left body, and the sync port on the right body - and with a T connector - ties that to the stock IAP hose.
The way I understand it is:
Version #1: tie both bodies together with line and T connector. Splice T connector into IAP line (both ends of the IAP line remain where they are from factory. Tie both T connectors together with line.
Version #2: Tie IAP port (on left body) to right body with line and T connector. Tie stock IAP line into empty side of T connector. No cutting the IAP line (gray). Don't remove rubber cap from left body.
Sound right? I went with the Version #2, based on the latest post from MoFlow about it. Is there a reason I should go back to Version #1, which is the way Invader originally posted it???
post #338 of 374 (permalink) Old 11-14-2012, 09:08 PM Thread Starter
I guess I have more posts to edit... Go with the best and most simple configuration #1, with a single 6" (15 cm) long 1/8 or 5/32" (3mm) ID vacuum hose on both TB vacuum ports. Leave the left outer IAP hose alone, and forget about using a T:
post #339 of 374 (permalink) Old 11-14-2012, 09:49 PM
Invader,
Thanks for weighing in here. For the benefit of anyone who may read this later - the photo above is yet a third option, at least since my posts. Do you think there is performance benefit to going with this last option (in your photo above)?
I have already reinstalled the tank etc, and currently have it as the #2 option in my previous post (which I believe was originally posted by you somewhere).
If there is an improvement - I'll take it apart again. But if it would only be a simpler option, then it's probably MORE simple for me to leave the tank/air box on at this point
Appreciate all the help folks. Maybe there should be a definitive sticky for this mod???
post #340 of 374 (permalink) Old 11-14-2012, 10:19 PM
Just a comment: You don't have to remove the gas tank to do the mod as Invader has just shown with the last set of photos. I was able to hook up the single line between throttle bodies with a nice long pair of needle nose pliars. Lot faster than removing the tank.....
Human Verification
